Hi. I recently received the UGreen HD USB Video Capture Card.
My set up is a PS5 with a single gaming monitor. I also have a high spec laptop with one HDMI Port. I am struggling to see how I use with to record/stream the gameplay to my laptop with the capture card while playing my games on my monitor due to the PS5 only having a singular HDMI port. Can anyone help please as I am unsure if I’m having a dumb moment or not.
Cheers
https://linustechtips.com/topic/1558546-capture-card-help/
I looked up the Ugreen product on amazon
https://www.amazon.com/UGREEN-Recording-Streaming-Teaching-Conference/dp/B0BGMYPBF4
Looks like it only captures from USB output, so a phone, camera, or laptop.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1558546-capture-card-help/#findComment-16322944
Hiya mate. Thank you for the response.
would this one work please?
https://linustechtips.com/topic/1558546-capture-card-help/#findComment-16322950
I think that would be a better choice. HDMI in, HDMI out, and USB connection, that is the best setup for a console that you want to record to your computer.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1558546-capture-card-help/#findComment-16322964
