4090 fan rpm normal?
Solved by matt0725,
A 10% difference could easily be down to a different case/ventilation situation compared to how it was tested by techpowerup. they likely used an open air bench, where your GPU is likely inside a case, so it has to fight a bit harder to get the heat out. I wouldn't worry about it at all.
Featured Topics
VinSen ·
1
Fahizzle ·
6
INotPablo ·
Posted in CPUs, Motherboards, and Memory1 -
nugget1414 ·
Posted in General Discussion0
