I am very new with this.
I have set up a home server at home using 'TrueNAS' as the operating system (this is an old PC that I had lying around). This home server is used to stream movies, series, and music to my TV and laptops. I use 'PLEX' for this purpose. When I installed TrueNAS, set up movies, and installed Plex, I could stream everything perfectly to my laptops and TV.
I don't use my server every day, and to save power, I turn off my server. However, when I want to stream movies via 'PLEX,' 'PLEX' can no longer find my server. Is there a way to use PLEX after the server has restarted?
server is directly connected to my router.
Thank you in advance.
Not really. The server needs to be online, if you want to stream from it. If possible, you could try configuring the BIOS to boot on LAN. Then it should start up if you try reaching the IP of the server. The configuration of boot on LAN can be different from BIOS to BIOS, depending on manufacturer and BIOS version. Therefore you should lookup the steps for this configuration for your Mainboard.
I don't use my server every day, and to save power, I turn off my server. However, when I want to stream movies via 'PLEX,' 'PLEX' can no longer find my server. Is there a way to turn off my server and still be able to stream movies via 'PLEX' when I need to use my server again?
So PLEX is installed on the server?  But you want to stream when the server is off?
Logically, how would that work?
Put a wifi outlet in there, plug the server into it.  Turn it on when you need it, remotely.  Wait 2 minutes, watch PLEX.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
sorry, English in not my native language. post is edited.
i mean when i restart my server.
thanks, i will try this
1 hour ago, StillerMarcel said:
Did you check, if the app is confgured to autostart in TrueNAS?
This.  I have my PLEX Server app to start on Windows startup.
I tried Boot from LAN but didn't do what I wanted.  I like the ability to restart the server, turn it off or on remotely.  Since people access it while I am at work  or away.
Using a Kasa Wifi outlet thing, coupled with Boot with Power setting, is a good way  around it.
OnePlus Ecosystem:
3D Printing:
TrueNAS isn't really intended to be turned off. If you have the right hardware it can idle at pretty low power levels.
You could just host your stuff from your desktop.
Theoretically plex should automatically start when you boot up trueNAS. It may be an IP problem and you could possibly fix it by assigning a static IP on your router to trueNAS.
I have always had weird issues with using apps or jails in truenas with less control over them.
This was one reason I switched to virtualize truenas under windows and passing through the drives.
Having Plex installed on the same server would be more useful here. For TrueNAS Core, there are basic apps including Plex available in Jail. On TrueNAS Scale, on the other hand, Plex can be found in TrueCharts or Docker. The service should resume after a reboot. (Note: Docker is no longer bundled since Scale version 23.10.1, requiring manual installation.)
Also, try making more reasonable schedules on power-on & -off, for example, shut the server down from 0:30 to 8:30, or your regular bedtime.☺️
Thanks, for the reply!
