CPU issues
Solved by unclewebb,
1 hour ago, Adrian_ae said:i shouldnt expect the effective clocks during gaming sessions
The Effective Clock is mostly a measure of how loaded a CPU core is. It would have made sense for HWiNFO to report this as a percentage instead of a MHz value.
When lightly loaded, it will read less than the maximum clock speed. When a core is fully loaded, it should show the same value as what the Core Clock value shows. It is mostly a meaningless number except when all cores of a CPU are 100% fully loaded.
