I bought one of these: http://www.ebay.co.uk/itm/201089482606
Now, the item arrived fine and works as it should and is reducing the humidity in my room. The power brick however is getting extremely hot to the touch and sparks whenever it is moved. Being worried it could be harmful i have turned it off and unplugged it. Now, with it being from ebay. Should i request that they just send a replacement power brick or replace the whole unit? It's only the power pack that seems to be faulty as the actual unit is working great.
Case: Phanteks Enthoo Pro | PSU: Enermax Revolution87+ 850W | Motherboard: MSI Z97 MPOWER MAX AC | GPU 1: MSI R9 290X Lightning | CPU: Intel Core i7 4790k | SSD: Samsung SM951 128GB M.2 | HDDs: 2x 3TB WD Black (RAID1) | CPU Cooler: Silverstone Heligon HE01 | RAM: 4 x 4GB Team Group 1600Mhz
https://linustechtips.com/topic/155594-mini-dehumidifier-power-brick/
Sparks whenever its moved?.... what?! that's a serious issue you should get checked out. I'd ask em to send you a new power brick.
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
It seems to also play havoc with my powerline adapters, whenever it's on it seems to cause a large amount of interference which causes near complete disconnection on my PC.
