Its a ryzen 5600 B350F on a tower cooler
I had my PBO enables, all cores offset -30
And reaching 4.65GHz and 4.12GHz in stress test
Then i tried manual setting it to 4.8GHz and raise cpu voltage from same setting above
But i realize the cpu drawing 60W at idle
Are these settings contradicting?
Curve optimizer and cpu voltage
Also are there minimal to none benefits in manual OC a 5600 for just gaming ?
While stress test, why would clocks drops 0.3-0.4GHz from my target clock? Anyway to set it right at 4.65 or 4.8 ?
https://linustechtips.com/topic/1555785-question-about-ryzen-overclocking/
Basically yes. Sure you can smash it at 4.8 IF it's a good overclock and get a bit better performance at the cost of much more power draw but usually not worth.
As for what I mean with good overclock do a cinebench with every change on boot as sometimes a higher clockspeed actually lowers score as the oc is not working properly. Seen it happen a lot with ryzens.
