So my mom got the ASUS TUF gaming A16, and it had some weird issues. It would take like a minute to boot to up, with most of the time the screen being black, then the fans turning on, then after logging into windows the screen would flicker 1 time. Then it just randomly turned the screen off, and i had to hold the power button to shut it down, after that it wanted to do a bios update, and after updating nothing rlly changed.
https://linustechtips.com/topic/1555668-weird-laptop-issue/
Is this a new laptop? If so return it or if possible exchange it for another one. Sounds like it has either defective parts or something with the software is messed up. If it's brand new I'd recommend just returning it asap and getting a new one over trying to fix it.
If it's used, that's a whole different ballgame.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1555668-weird-laptop-issue/#findComment-16304149
yeah just got it today, thought about returning it, and probably will
https://linustechtips.com/topic/1555668-weird-laptop-issue/#findComment-16304156
Maybe try spending a few minutes doing driver updates, if that doesn't fix anything though, I wouldn't spend a ton of time on it. I'd just return it. The sooner the better.
https://linustechtips.com/topic/1555668-weird-laptop-issue/#findComment-16304186
