Hello, since I built my pc I have been experiencing freezes and lags although I have a good cooler for my cpu, and a decent gpu and cpu.
I have tried swapping the ram, and it fixed the problem a little bit, I have thoughts that it might be my vertical gpu mount but I want to know first what the issue can be.
I have'nt experienced a BSOD but after my pc has been on for a while (can change from time to time how long it takes until it does that)
I also have a pretty reliable ssd that have good reviews and all my drivers are up to date too.
The thing I'm a bit worried about is that my ram rgb is lagging when my pc is on heavy (but not that heavy) load, could it be the Icue software that causes this freezing and lag? Could it be the power outlet?
If you want specs and temps here they are:
5700X 35-57C°
4070 28-70C°
64gb 3200mhz ram
Nothing is overclocked
I am reposting this because of no answers on my last post. Just a reminder if you want to see my replys and stuff make sure to follow the topic, thank you.
https://linustechtips.com/topic/1555093-freezing-and-lagging-issues/
