@alexej1 That sounds like just more than enough. The i7 3820 doesn't overclock that much does it? it isn't part of the K edition of Sandy Bridge-E processors like the 3930K or 3960X.
I would get a hold of 2 good static pressure fans i.e. Noctua NF-F14. I would doubt you need to use a fan to dissipate the 120mm radiator since the passive airflow in your case will be enough.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
Kind of pushing it, I would go for two 240mm's.
But if you actually read the post (you never do that), you would notice that he can only fit the 280mm + 120mm radiators.
Ontopic: 280mm + 120mm will be just fine, but I would try to get +15fpi radiator for that.
Curing shitposts by shitposts
Doesn't matter.
He could be using a shoe box for all I care, my answer would be the same. The components are what is relevant.
Take your sass elsewhere.
Error: 410
Why even bother posting then?
Because
so I posted what he should use based on his components.
Note that an equivalent surface area can be substituted for standard 30mm rads.
If you failed to understand completely what I meant by my original response, you could interpret it as:
"what I think about your choices is that it is just enough to work, you should obtain more radiator space somehow"
Error: 410
