im modding my case for airflow and i have questions
Solved by OhioYJ,
I would pick up a hole saw next time. You'll end up with a round hole, and it's much easier than using Dremel for something like this.
Being at the top, I would still probably make it exhaust. Especially as the PSU is an "exhaust" right there next to it.
I used to drill holes in a "grille" pattern in the 5.25 bay covers and mount a fan in there below the CD-ROM. However those are fairly decorative, so I'm not sure if you want to drill them or not.
Almost looks like you could get a 40mm there next to the IO shield, that could be an intake? What about a side cover? I've used these grilles a couple timea recently.. They make them in different sizes.
