need some help with ram compatibility
7 minutes ago, cyberlyxn123 said:all i can find online are old reports of people having a stroke because their intel xmp ram only runs at 4800mt/s
XMP on the original AMD BIOSes was broken. On current BIOS revisions, it has since been fixed, so if you do a BIOS update before using the system (which you should do anyway to avoid the SOC voltage issues of the original BIOS revisions), this isn't something you need to worry about. Even on the older BIOS revisions though, you could get an XMP to work just fine by leaving XMP disabled and manually entering all of the memory settings yourself.
On AMD, if you just want to enable XMP/EXPO, stick to 6000MT/s. Speeds of 6200+ will default to 2:1 mode and end up with significantly worse performance unless you manually set it to 1:1 mode and hope you don't have one of the bottom bin memory controllers that doesn't do 6200MT/s in 1:1 mode. As for it not being on the QVL, the QVL isn't exhaustive so odds are the kit should work just fine.
