Outdoor WiFi between two buildings
Takoren
I am hoping someone can help me out here.
I own a few acres that has a road running through it, on one side I have my house and on the other I have a workshop and a couple of trailers for when family visits.  I would like to share the wifi with the trailers from my house, running a wire isn't really an option as I would need to bore under the road to do so and that's cost prohibitive.  What I would like to do is setup a couple of wifi transmitters, one at my house and on the other side of the road for the trailers/shop.
Could anyone recommend some hardware solutions to accomplish this?  I am fairly tech savvy and can do some basic networking if needed.
The distance needed to broadcast is 50 to 75 yards but would like to cover up to 100 yards if possible.
Any help is appreciated.
You should get a Yagi Antenna and a wifi router that is capable of accepting external antennas and call it a day. Or a wireless access point that connects to your router.
Yagi antennas are powerful directional antennas.  Plus they're reasonably cheap all things considered. roughly 30$ each sometimes 15$ if you search on ebay. So you can have multiple ones to extend the range/coverage.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Get a pair of Unifi Loco M5ACs and call it a day. There are tutorials available for setting them up as a wireless bridge. The catch (maybe) being that they're passive PoE powered (but you can buy PoE+ adapters).
That seems like overkill/tinkeryish for a few hundred feet...
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB /
TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
I used this for years, but its a bad solution today given they are usually only 2.4Ghz and modern WiFi is designed around 2x2 MIMO so you'd need two of them for best performance.
WiFi is also not really designed with outdoors in mind, it can pickup a lot more interference than indoors.
Far better to have a proper outdoor point to point network setup which is designed to deal with outdoor conditions, has a better signal strength due to not having the loss from the long antenna cable, will work at 5Ghz (or possibly 60Ghz)  and have a normal AP connected to the one in the other property.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Look into point-to-point (PtP) or point-to-multipoint (PtMP) wireless bridging.
Tutorials can be found on CrossTalk Solution's Youtube channel.
