Posted January 19 I'm working on reviving an old pentium 4 machine, and with this project I bought a modern case so I could cool it better than it ever has before. But the new case only has the 19 pin usb 3.0 connector for front-panel usb while the motherboard only has 9 pin usb 2.0 headers. I was wondering if these the connector is somehow backwards compatible with the 2.0 headers. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 19 Solution yep https://www.amazon.com/LINKUP-Motherboard-Compatible-Converter-Chipset/dp/B084D58HBP/ref=asc_df_B084D58HBP/?tag=hyprod-20&linkCode=df0&hvadid=459618435588&hvpos=&hvnetw=g&hvrand=12504895071011257553&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019461&hvtargid=pla-948332373276&psc=1&mcid=b1342285891833a7966693031256d70c&gclid=Cj0KCQiA2KitBhCIARIsAPPMEhL1tF7PEbB8FLMZXs_Les76p54E2I2xV31ldBeKSLwA_BkkEW18BPEaAnMbEALw_wcB Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 19 Author That is exactly what I need! Thank you so much! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
