Budget (including currency): 700 euro's + 100-150 for a monitor
Country: Netherlands
Games, programs or workloads that it will be used for: Valorant, Stray, Horizon zero dawn, Minecraft
144Hz, 1080p, no existing parts, I have a mouse, keyboard, and headset, I want to buy before coming summer
https://linustechtips.com/topic/1553469-first-pc-build-help/
sounds like you could wait for deals,
at 700€ one of the angles is good old 5600 build,
this build doesn't include a GPU, and would leave roughly 300€ budget for it, which would leave room for some decently powerful GPUs, (doesn't have monitor either)
based on if you're comfortable getting GPUs from second-hand market, you could get even more powerful ones, though the build might need stronger PSU for that..
As for the build itself, it could maybe use a higher quality Motherboard, this one works, but it probably won't handle any faster CPU than 5600:
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€135.95 @ Megekko)
Motherboard: MSI B450M-A PRO MAX II Micro ATX AM4 Motherboard  (€54.90 @ Amazon Netherlands)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€36.99 @ Amazon Netherlands)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€62.90 @ Azerty)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (€45.90 @ Amazon Netherlands)
Power Supply: be quiet! System Power 10 650 W 80+ Bronze Certified ATX Power Supply  (€64.95 @ Paradigit)
Total: €401.59
Generated by PCPartPicker 2024-01-18 19:58 CET+0100
current PC:
PC configs I used before:
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288667
Right now this is the best i could find if you want to buy all new and would want to buy right now
Motherboard: Gigabyte B550M DS3H Micro ATX AM4 Motherboard  (€92.85 @ Azerty)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  (€37.90 @ Amazon Netherlands)
Storage: Lexar NM710 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€63.85 @ Megekko)
Video Card: PowerColor Fighter Radeon RX 6650 XT 8 GB Video Card  (€262.95 @ Megekko)
Case: Deepcool MATREXX 40 3FS MicroATX Mini Tower Case  (€54.56 @ Amazon Netherlands)
Power Supply: Gigabyte P-B 650 W 80+ Bronze Certified ATX Power Supply  (€66.29 @ Amazon Netherlands)
Monitor: AOC 24G2SPAE/BK 23.8" 1920 x 1080 165 Hz Monitor  (€129.00 @ Azerty)
Total: €843.35
Generated by PCPartPicker 2024-01-18 20:14 CET+0100
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288686
Hello... I think given your budget, this would be the best PC for you. Please let me know what you think.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://nl.pcpartpicker.com/list/JCsKGP
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor  (€99.95 @ Megekko)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€38.99 @ Amazon Netherlands)
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€93.59 @ Amazon Netherlands)
Case: MSI MAG FORGE M100R MicroATX Mini Tower Case  (€60.95 @ Azerty)
Power Supply: MSI MAG A650GL 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€97.00 @ Amazon Netherlands)
Monitor: ASRock PG27FF1A 27.0" 1920 x 1080 165 Hz Monitor  (€171.09 @ Amazon Netherlands)
Total: €879.42
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288687
isnt that the case that has bad airflow because cooler master decided to use a solid front panel with holes in(+ mesh on top) it instead of just mesh?
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288689
not sure, so that meshy looking front could be just holes? anyways, does airflow even matter if the CPU's TDP is 65W?
https://nl.pcpartpicker.com/list/kBkDMV
Storage: Crucial P3 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€63.90 @ Amazon Netherlands)
Total: €849.73
not the P3:
current PC:
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288701
Yes its the one there is a solid panel with holes in it behind the mesh, but yea with a5600 and maybe a 6650XT it wont mater as much but maybe a case upgrade would also bee needed when upgrading
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288732
not the P3:
I fixed it. I changed it to the P5 Plus.
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288738
that's quite expensive, could get Kingston NV2, as it's good in terms of price/performance: (unless the budget allows P5 Plus but even then I'd rather get something like better MB or PSU)
current PC:
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16288791
isnt this also the same case that a user in this forum had to buzzsaw to get any decent fan mounting? The case temps is on par for the liter on stock but there's 0% upgrade from there.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1553469-first-pc-build-help/#findComment-16289118
