Drive Cloning Help!
Solved by porina,
Macrium reflect trial version used to be a go-to for this use case but I think with recent changes that might not be an option any more. I've looked at Clonezilla as alternative but never used it. If the hardware is too different it might not boot, but Win10 and newer seems pretty good at sorting itself out.
Software may or may not work after a clone. It depends on how they implemented their copy protection. A change in hardware may break that.
Retail Windows licence should be transferable, but I've never done it. OEM versions are tied to hardware so you may need a new licence. If you need a new one I'd just get one of the suspiciously cheap keys from resellers.
