Bluetooth Keyboard Ghosting or Lag or Not Recognizing Typed Keys
Solved by Donut417,
13 hours ago, milesuy said:Is this normal for Bluetooth keyboards?
In my experience it can be. I have the K6 and some times when I connect it to my Mac via Bluetooth I will some times have lag. Generally turning the keyboard off then on again helps. The fact is Bluetooth isnt the best wireless standard. There is a reason gaming Keyboards use proprietary wireless standards. For me its a non issue because I use the Bluetooth function when Im in bed with my Mac hooked to the TV for streaming video.
13 hours ago, milesuy said:and a WiFi router 90cm/3ft away,
This could defiantly effect it. Not to mention if your neighbors are close by and their 2.4 Ghz network is also in shouting distance.
