Help me choose
Go to solution Solved by emosun,
7 minutes ago, BallzDeep said:
I know these will get me about a year till they are complete obsolete.
it's not the 1990s anymore , you can run a machine for as long as you want. case and point: typing this from a 2011 HP dv6 on windows 7
given the two options i'd probably just go for the 4060 build to extend it's driver lifespan but neither machine has enough info to really determine the quality or longevity of the parts being used.
13th gen I7 13700f, liquid cooled  16gb ddr4 3200,  geforce rtx 3060 8gb, 1 tb nvme m.2
Or
13th gen I5 13400f, fan cooled, 16 gb ddr5 5200,
Rtx 4060 8g, 1tb nvme m.2
Not sure what would be the better of the two 🤔
I know these will get me about a year till they are complete obsolete. But this is what i can afford. For a pre build
https://linustechtips.com/topic/1552229-help-me-choose/
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279486
What's your use case going to be with your PC? Do you currently have a PC and if so which games you play or struggle to play but would like to?
Are pre-builts the only options?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279492
Frankly, I would avoid both since the GPU is either 3060 or 4060, especially with prebuild that cost $1000
I would at least consider if it's 4060 TI, but no less than that
Is there any other prebuilt list that you have checked?
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279497
1 minute ago, BallzDeep said:
Ive had an alienware for 13 years now, steam no longer supports windows 7 , so im forced to upgrade. Cant even play 7 days to die anymore without windows 10 or better.
have you tried installing windows 10
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279503
I really want the rx 6700 xt but dosent support ray tracing
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279504
5 minutes ago, BallzDeep said:
Whatever case it comes with.
"use case" aka "what you will do with that PC when you finally have it home?" (play games, video-editing, programming, 3D modelling, all of the above)
current PC:
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279508
I'd pick the i7. The margin between the 400f and 700f is significantly bigger than the 3060 to 4060. Better future upgradability.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279514
I'd pick a system with 7600 CPU, but I think those are 100$ overbudget unfortunately, at least for pre-builts
current PC:
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279516
1 minute ago, emosun said:
it should be , if the machine supports 7 then it'll run 10. there shouldn't be any drivers a stock alienware has that aren't available in 10
When i try to update to windows 10 it tells me that my processor isnt supported.
xeon 12 core LGA not sure the exact number.
Liquid cooled
16 gb ddr3 3200,
Gtx 960 ssc kingpin
4tb storage ssd Ran in raid.
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279517
Hello... The RX 6700 XT does have Ray Tracing, it's just not as good as NVIDIA. Please have a look at this Build I have for you and let me know what you think.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://pcpartpicker.com/list/gTfRCd
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($169.00 @ Amazon)
CPU Cooler: Thermalright Assassin King SE ARGB 66.17 CFM CPU Cooler  ($19.29 @ Amazon)
Motherboard: MSI B550 GAMING GEN3 ATX AM4 Motherboard  ($109.99 @ Amazon)
Memory: Silicon Power XPOWER Zenith RGB Gaming 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($69.98 @ Amazon)
Storage: Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($107.99 @ Amazon)
Video Card: XFX Speedster SWFT 309 Radeon RX 6700 XT 12 GB Video Card  ($349.99 @ Newegg Sellers)
Case: MSI MAG FORGE 112R ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Amazon)
Total: $1016.22
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279518
Where is 7600? I only see choice of 2 Intel systems. Neither that great.
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279523
Total: $1016.22
Seems cool, im not a fan of AMD tho. My intel has been more than reliable. So im sticking to what i know best
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279525
on ibuypower website there's 1100$ prebuilt with 7600:
and you stick to Intel because you know or because you've been running an Intel system for 13 years?
current PC:
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279526
why X?
current PC:
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279529
2 minutes ago, podkall said:
on ibuypower website there's 1100$ prebuilts with 7600:
All my pc's have been intel. I know my way aroud them and how to service and use there features best for me.
Amd just has a bunch of bloat ware attached to them.  If you need 5 programs to run your cpu and monitor it. To me that just a huge headache
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279531
Still pretty bad. 4060 with slow ram. We don't even know what sort of case it is nor motherboard. For all we know they could be shaving fat margins and give you a mATX motherboard in some cheapo ATX case. On PCPartPicker for RAM, storage, PSU, Case, Cooler we've got a fat $600 budget. For gaming I'm pretty sure the 7600 and 13700F are neck and neck. I'd just keep the $100 saving then.
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279532
but you don't need bloatware or 5 programs to monitor AMD CPU
current PC:
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279533
Outdated stereotype that wasn't true to begin with. Your prebuild is gonna come with bloatware regardless if intel or AMD, because it's a prebuild.
In 2024? AMD is top dog as Intel struggles to keep up and is starting to play dirty, falling back to their tricks that made CPU's stagnate to begin with.
How is building and maintaining an Intel system different from AMD?
What are these mystical features that only Intel has that you can't live without because nobody else has them. Curious.
https://linustechtips.com/topic/1552229-help-me-choose/#findComment-16279535
