Looks like D15 connector, which also can be used for DSUB. I would make sure pinout is the same, medical devices can be super shitty to deal with due to that.
https://linustechtips.com/topic/1552090-cable-help/#findComment-16278406
I was thinking its DA-15 DSUB but not sure if the top line is 8 pin or 6 with the two pins white out. I will see if I can find a device manual online.
https://linustechtips.com/topic/1552090-cable-help/#findComment-16278434
