First Gaming PC Build
3 hours ago, ZF-Bappo said:Hello everyone,
I am planning on building my first gaming pc, as my laptop isn't performing sufficiently anymore apart from being really noisy to a point where it's disturbing. I looked into parts as far as I understood and created this list on Pc PartPicker and was hoping for some feedback:
https://pcpartpicker.com/list/LN8HJy
I used @Windspeed36 's build thread template below.
If the above list doesn't work here's a short summary of components:
-CPU
Intel Core i7-14700KF 3.4 GHz 20 Core
-CPU Cooler
be quiet! Pure Rock 2 Black CPU Cooler
-Motherboard
Asus Prime B600M-K D4 Micro ATX LGA 1700 Motherboard
-RAM
Corsair Vengeance LPX 32 GB (2x16GB) DDR4 3600 CL18 Memory
-MEMORY
Crucial P3 1 TB M. 2 2280 PCIe 3.0 X4 NVME ssd
-GPU
Gigabyte EAGLE GeForce RTX 4060 Ti 8GB Video Card
-CASE
Corsair 4000D Airflow ATX Mid Tower Case
-POWERSUPPLY
be quiet! Pure Power 12 M 650W 80+ Gold Certified Fully Modular ATX Power Supply
1. Budget & Location
Budget: ~1400usd /~1250€
willing to increase 10% for more performance
2. Aim
Gaming
-Ready or not
-Subnautica
-Sons of the forest
-Lego Star Wars Skywalker Saga
3D-Modeling
General usage (Web Brosing, Text formating etc.)
3. Monitors
current: 1x 4k 50'' Monitor
in the future: thinking about adding a small (HD 18-22'') secondary screen
4. Peripherals
peripherals: no peripherals needed
os: windows 10
5. Why are you upgrading?
The reason for upgrading is as mentioned above the dropping performance on my current gaming laptop, the noi se and the want for more performance and quality.
Thank you for any feedback and please excuse poor formating as I am currently on mobile.
Hello... I was looking over your list and I found a few things that really needed to be changed.
1. If you are just going to be mainly Gaming then you don't need a Core i7 or a 14th Gen either. Also you don't want to pair it with a B660 Motherboard because you would need to update the BIOS on the Motherboard and there is no BIOS Flashback on it so the CPU would not work. So I switched it to a Core i5 12400. It is more than enough to play Games and do everything else you need. If you ever wanted to upgrade the CPU you can put in a 13th or 14th Gen.
2. A Be Quiet! Pure Rock 2 would not be enough to Cool a i7 14700, it would overheat and either refuse to boot or fry the CPU and or Motherboard. I got you a Thermalright Phantom Spirit Air Cooler. It is almost silent and is more than enough to cool even a Core i9.
3. With Gen4 M.2 Drives so cheap these days why would you want to limit your PC and not unlock it's potential? I switched it to a Gen4 Drive.
4. I was able to upgrade the GPU you had to a model with 16GB of VRAM. Trust me, you will need the extra Video Memory.
5. Lots of people still pick the Corsair 4000D Airflow Case. It is not bad but it only give you 2 Fans and you will need more so why not get a Case that already has enough Fans, there are so many other good options. I went with the MSI MAG Forge 112R, it has 4 ARGB Fans already installed.
6. A 650w PSU will not be enough so I added a 850w from MSI and it is A-Tier Rated. If you ever upgrade the GPU you will need a the extra Wattage so I already did that for you.
I went with a MSI Themed Build. I hope you like it. Let me know what you think. Also I added a second list, a AMD PC.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://uk.pcpartpicker.com/list/GBYLfy
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor (£159.98 @ Scan.co.uk)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler (£42.22 @ Amazon UK)
Motherboard: MSI MAG B760 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard (£183.48 @ Amazon UK)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (£80.83 @ Amazon UK)
Storage: TEAMGROUP Cardea Zero Z440 Graphene 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£111.30 @ Amazon UK)
Video Card: MSI VENTUS 3X OC GeForce RTX 4060 Ti 16 GB Video Card (£471.48 @ Scan.co.uk)
Case: MSI MAG FORGE 112R ATX Mid Tower Case (£80.63 @ Amazon UK)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£108.99 @ Amazon UK)
Total: £1238.91
https://uk.pcpartpicker.com/list/kHkjbL
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor (£167.10 @ Amazon UK)
Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI ATX AM4 Motherboard (£159.97 @ Amazon UK)
Video Card: PowerColor Fighter OC Radeon RX 7800 XT 16 GB Video Card (£500.69 @ Amazon UK)
Total: £1251.73
