Subwoofer connection to PC/TV combo
leclod
I currently use my subwoofer directly on the TV headphone Out via a crossover frequency. It works alright enough.
But can you confirm there's no better way via the Center/Subwoofer out on the motherboard ? (I use an HDMI cable and the TV stereo speakers which are ok on my TV)
Can HDMI audio signal and that Center/Subwoofer Out work in parallel ?
Does that Center/Subwoofer Out only work with a dedicated subwoofer track ? meaning 2.1 audio source...
Edited by leclod
I'm willing to swim against the current.
Centre/subwoofer plug on motherboard is intended for 5.1 PC speakers or legacy connection to older amps which almost no one use nowadays. I don't think that plug will work as there's no 2.1 option + bass direction on Windows. You could plug your subwoofer into stereo plug instead and then use Voicemeeter to dual output HDMI and Realtek audio, but ehh... I don't know if that's better at all.
At that point if your current setup works for you then there's no need to worry further. What would be better is ditching TV speakers and getting stereo amp or active stereo speaker then combine with your sub. It will open up several more ways to connect depending on what connections your speaker, amp and sub have.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
Thank you. I'll give Voicemeeter a go.
One of my issues is latency. If dual output works it might help synchronise TV speakers and Sub by eliminating one intermediary on one side (if this ever was an issue in the first place)
The speakers on my LG 65E7 are above average.
Edit : I installed Voicemeter, it did mess with my GPU (Afterburner is orphaned), with Fan Control, with the display style (windows edgy now instead of round corners) 😬
Edited by leclod
Strange. I only used voicemeeter as an experiment but haven't used it since. It didn't mess up what you listed at that time.
Also I'm guessing there is no latency difference with your current setup (but never tried). I would be worried with higher end DAC products which may introduce more latency as more features are shoved in.
