Trying to get back into folding. But 13 days for one work unit it a bit outrageous.
[spoiler=»--((¯`·._.·¤~●oO му яιg Oo●~¤·._.·´¯))--«] Case: Corsair 600T White       CPU: Core i7 3930k @ 4.3GHz                     SSD: Crucial M500 480GB
MB:    Asus P9X79 LE         GPU: Nvidia GTX 780 Reference             HDD: WD Caviar Green 3TB
PSU:   Seasonic X-1050      RAM: G.Skill Trident X 32GB @ 2.4GHz   ☃ There are 10 types of people in this world. Those who understand binary and those who don't.
https://linustechtips.com/topic/155053-low-ppd-gtx-780/
Do you have any power saving features enabled or anything?  Are you using beta drivers?
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2066981
don't forget the classic "are you overclocking?"
it might be better if you go into the actual folding client on your computer, the advanced view and see what's going on there instead of using the web client, and remove the advanced/beta flag, it might be a bad unit.
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067022
Tbh, all the times I've OC'd things whilst folding/ mining I've never had issues, I'm not quite sure why people always ask that question lol xD
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067075
No power saving features.
Driver version 335.23
Tried without flags. I get 37 days per work unit.
Stock clock speeds, stock voltages. Still nothing.
It's more than likely an issue on your side, and not something on the side of Folding@Home.
My 780 is working just fine. Getting about 300K PPD
300K PPD on one 780?
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067471
That's what it was saying the other day. Now it's only saying 50K PPD, so maybe it was just a bug.
I used to get 130K PPD
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067507
Just let FahClient calculate! it will sync eventually.
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067511
I thought it would eventually, but after a few hours it was at 0.06 percent...
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067540
Here's the wu with no flags
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067550
remove the slot pause it close f@h remove it reboot install it again then ad the slot again let it sync up.
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2067685
damn son, your card is f*cked up O.o
at what speeds is it running under folding and under gaming load? maybe it throttles to like 300mhz.
Also disable all the oc's on the gpu.
I get 120-180k with my 780
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2068057
stock clocks, 954 Mhz with the boost
It was definitely something with wu.
After 297252234 tries, I've got a proper wu.
still only getting 50k
but I'll take that over 371 ppd
hopefully once this work unit is complete, I'll get some better ones
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2068420
Thats quite the pleasant bug
And have you tried turning it off and then back on again? (I say this half joking half serious)
- "some salty pretzel bun fanboy" ~ @helping, 2014
- "Oh shit, watch out guys, we got a hopscotch bassass here..." ~ @vinyldash303
- "Yes the 8990 is more fater than the 4820K and as you can see this specific Video card comes with 6GB" ~ Alienware 2014
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2068832
Yea, it doesn't happen anymore  :P
That's sad, did you perhaps get blessed by an old Shaman woman or crow spirit?
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2068882
did you try and receive new units after removing the advanced flag? the advanced flag basically amounts to you saying you want to receive late stage beta units when they are available, still in testing nonetheless, that means there is a chance you could receive some wonky work units that don't work exactly as they should or as you expect them to. '
you could check out the gpu usage aswell to see if the gpu is working stable with a fairly constant high gpu usage as it should.
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2071775
As @tobben says - no one should be using the BETA or ADVANCED flags or you will get weird WU's that take a LONG time or won't - but don't actually reward any points.
Also, deleting and re-adding a slot won't get rid of the WU's. It will still be there waiting for you. You need to delete the WU itself.
Stop FAH
Start - Programs - Folding Client - Data Directory shortcut
Now, go into the Work folder. You should see some folders that are numbers. These correspond to the Slot number. Go into the one for your GPU and delete everything in it.
Start FAH and it will download new WU.
BUT - do not do this very often. You will trash you stats and eventually PANDE can ban your account if you do this to much. Happened a lot when Core17 first came out and people trying to cherry pick.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2072298
Turned out to be a driver issue, and yes, I was properly deleting the work units after removing the flags.
I'm using 327.23 WHQL, and I'm getting ~120k PPD while the PC is in use and ~130k PPD when the PC is not in use. Stock settings on a reference 780, 954 MHz, no flags other than next-unit-percentage = 100.
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2074000
oh right.. they stopped giving points for beta/advanced units didn't they   :mellow:
Not all, but most, ya.
https://linustechtips.com/topic/155053-low-ppd-gtx-780/#findComment-2076546
