First Pc Build LF advice
Go to solution Solved by PC HEROES,
9 hours ago, iTsEko said:
Budget (including currency): 2000-2500 usd
Country: USA
Games, programs or workloads that it will be used for: Escape From Tarkov, Warzone, PubG, The finals, Ark Survival Ascended , Survival Games
 if someone can check out my parts list and tell me if its good or give me better parts for the money pls
PCPartPicker Part List: https://pcpartpicker.com/list/9wsY28
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($389.00 @ Newegg)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  ($54.99 @ Amazon)
Motherboard: *MSI PRO X670-P WIFI ATX AM5 Motherboard  ($198.99 @ Amazon)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Amazon)
Storage: Samsung 980 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.99 @ Adorama)
Storage: *Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($119.95 @ Amazon)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XTX 24 GB Video Card  ($959.00 @ Amazon)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Amazon)
Monitor: Pixio PX277PRO 27.0" 2560 x 1440 165 Hz Monitor  ($349.99 @ Amazon)
Total: $2481.88
Generated by PCPartPicker 2023-12-30 20:36 EST-0500
Hello... I was looking over your list and there were some things that I had to change and some that I added but I still have it under your budget. This PC will get a little hot but not to worry... I have included one of the best Airflow Cases you can get and I also added 6 extra ARGB Fans (3 for the top of the Case, 2 for the top of the PSU Shroud, and 1 for the Rear) and a Fan Hub/Controller to help Cool the PC down. It will be whisper quiet if you hear anything at all and you will never have to worry about heat ever again. Please let me know what you think.
I have been building PCs for over 30 years so if you have any questions please ask. For future communication I use Discord for much faster response times as I have it open 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat. I can be with you while you build your new PC if you need me to be.
https://pcpartpicker.com/list/kG7TjH
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($449.00 @ Best Buy)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX V2 ATX AM5 Motherboard  ($199.99 @ Newegg)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Amazon)
Storage: Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($115.00 @ Amazon)
Case: Montech AIR 903 MAX ATX Mid Tower Case  ($75.00 @ B&H)
Power Supply: Enermax REVOLUTION D.F. 2 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Newegg)
Case Fan: Thermalright TL-C12C-S X3 66.17 CFM 120 mm Fans 3-Pack  ($13.59 @ Amazon)
Monitor: Acer Nitro XV1 XV271U 27.0" 2560 x 1440 180 Hz Monitor  ($179.99 @ Amazon)
Custom: Thermalright Fan and ARGB HUB ×8 ARGB/PWM Hub Controller Used SATA Power Supply, Hub Support 8 Groups of Fans, 8-Port PC PWM Fan and ARGB Fan Controller,PWM Fan/ARGB Lighting Hub(Fan and ARGB  ($10.90 @ Amazon)
Total: $2391.94
Country: USA
Total: $2481.88
https://linustechtips.com/topic/1550084-first-pc-build-lf-advice/
Country: USA
Total: $2481.88
Consider a slightly better PSU, https://pcpartpicker.com/product/Bjhv6h/adata-xpg-core-reactor-ii-850-w-80-gold-certified-fully-modular-atx-power-supply-corereactorii850g-bkcus.
If you can find a model that satisfies your aesthetic, the Thermalright Peerless Assassin 120 SE is less expensive and will do a good job.
Country: USA
Total: $2481.88
Total: $2391.94
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
It's pretty much all good, it's like my build.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
Total: $2391.94
thanks for the build info i will use i only question i have is how should the fans be oriented
The Lancool 216 has three stock fans installed, front intake rear exhaust. There is no reason to alter that configuration.
The tower cooler should be installed with the outer fan facing the case front. It intakes air which is moved through the tower and exhausted towards the rear case fan.
In the Montech Air 903 MAX, this Case comes with 4x 140mm Fans. 3 of them are ARGB Fans in the Front (the "A" stands for Adjustable)and 1 standard Non-RGB Fan in the Rear. I also added 6 more 120mm Fans. The rest of the Fans should be oriented as follows:
1. 3 in the inside Top of the Case to Exhaust Air Out
2. 2 right on top of the PSU (Power Supply) Shroud so that you Pull Air in from the Bottom
3. 1 to replace the Fan at the Rear of the Case to again Exhaust Air out.
There should be Arrows on the Fans to show which way the Air goes through the Fans, if not then usually the side with the Sticker Logo is the side that Air gets pulled in.
If you like my Build and would like to use it could you please mark my post as the Solution. Thanks very much. Please feel free to reach out again if you need anything else.
Edited by PC HEROES
3. 1 to replace the Fan at the Rear of the Case.
Will do and Thx
1 minute ago, iTsEko said:
Will do and Thx
No Problem, anytime.
