Eaton USB ups not shutting off
Solved by TheGreatestGazoo,
I had a Cyberpower UPS that beeped when it ran on battery and the alarm beep could not be turned off. Yours may be the same. I now have newer UPS systems for my computer and living room AV components and that has a button that can be pressed to silence the alarm. Look up your model number to get the manual and see if there is an option to turn off the alarm beep. If not, then you have to live with it when there is no power.
Featured Topics
1
Shadow1789 路
Posted in Cooling3 -
7
4
2
10
6
