Overheating or not? I7-14700k
Solved by RONOTHAN##,
Those chips are designed to be pegged at 100C, so it's not dangerous. It does mean that the CPU is thermal throttling though and that you're going to be losing some performance when compared to a higher end cooler.
If you don't have a contact frame, consider getting one as it's quite a bit cheaper than a new AIO and it helps improve temps quite a bit, though admittedly for a 14700K, a 360mm AIO is a pretty good idea.
Featured Topics
1
Shadow1789 ·
Posted in Cooling3 -
7
4
2
10
6
