SSD problem?
Go to solution Solved by Eigenvektor,
Swaping the OS from one PC to another isn't ideal, because they likely require different drivers. But in general it should work fine. Though you might run into issues later on.
To do a fresh install you can download the media creation tool from Microsoft and use it to create a bootable USB to install Windows.
https://www.microsoft.com/software-download/windows11
If the old PC isn't used anymore and your license is linked to a Microsoft account, you can use Microsoft's website to transfer the license.
https://support.microsoft.com/en-us/windows/reactivating-windows-after-a-hardware-change-2c0e962a-f04c-145b-6ead-fb3fc72b6665
https://linustechtips.com/topic/1549088-ssd-problem/#findComment-16259286
