Advice on buying a wireless headset
Solved by Tigerleon,
5 minutes ago, Yahhas said:My friend actually recommended me to get wired headphones and then some not too expensive mic. He recommended beyerdynamics as you can get for example the tygr 300r for 119€ and I noticed that you happen to be dailying it? So I guess my question would be are the worth it for that price?
Get them! You won't regret it. I use them daily yes.
Featured Topics
IR76 ·
Posted in Networking2 -
Blasty Blosty ·
Posted in Audio6 -
c0mplexx* ·
Skelitor ·
Posted in General Discussion6 -
1
4
11
13
