Does anyone know any low profile cpu cooler that fits on the asus tuf gaming b550m-plus wifi ii, something that is <77mm
Edit: the cpu im using is a 7 5700x and the cpu cooler I think would fit is a ID-coolig IS-67-ST but might replace the slim fan with an arctic p12 slim
Edited by NukoTi
Cpu im using
https://linustechtips.com/topic/1548021-small-cpu-cooler/
Noctua NH-L12S 55.44 CFM CPU Cooler (NH-L12S) - PCPartPicker
This cooler can have the fan mounted to the underside, making it ~70mm. Roughly ~80mm top mounted
You may run into RAM clearance issues though
I sell teeth and teeth accessories 🦷
https://linustechtips.com/topic/1548021-small-cpu-cooler/#findComment-16252122
Coolers are made to fit motherboards. Any compatible low profile cooler will fit your motherboard.
Noctua has some low profiles
ID-Cooling (can be bought from Aliexpress) has some, I use the IS-50X.
There are others, there are webpages and youtube videos dedicated to comparing them.
You should find the max amount of thermal Watts generated by your target cpu for a guide line.
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1548021-small-cpu-cooler/#findComment-16252124
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1548021-small-cpu-cooler/#findComment-16252142
