New 7800X3D System Build Question
7 minutes ago, Omnislash89 said:if I should be going with the BIOS version 1303, as stated on PCPartPicker, or the 1709 that appears to be the most recent released.
The 1303 on PCPP is the minimum revision needed to work. Go for the most recent though.
7 minutes ago, Omnislash89 said:I know the SOC Voltage issue was claimed to be "for maximum memory compatability" but community consunsus is that it's a cop-out by ASUS.
I do tend to agree with ASUS actually setting it that high out of the box though (at least at the time). AMD gave guidelines that 1.4V was safe, and ASUS just took their word for it. To be clear, their overall handling of the issue when it was deemed to be unsafe was bad, but it wasn't unreasonable for them to do that originally.
I do somewhat question the need for an X670E Gene in this system though. It's completely unnecessary for this type of system, with the main benefits of it being for extreme overclocking and running things like DDR5 8000+. If you're not doing that, a simple ~$150-200 mATX board will be more than adequate.
