Virtualbox - VM CPU slower than host CPU
Go to solution Solved by manikyath,
it's reporting wrong, that's all thats going on here.
On my host, my CPU turbos around 3.5-36 GHz with a base lock of 1.9 GHz.  In the VM, I’m only seeing the CPU run at 1.9 GHz.  My Execution cap is already set to 100% so I’m not sure what the issue is.  Anyone know how to get the CPU running faster?  Any help is greatly appreciated.
https://linustechtips.com/topic/1545678-virtualbox-vm-cpu-slower-than-host-cpu/
From what I’m seeing about other VMs and comparing to the VM I have at work, this seems to be the case.  Not sure why VMs only show the base speed.  Thank you
