Streaming Audio Recommendation
Hello Friends,
My cousin's headset died and he was asking me for audio recommendations. I am hard of hearing so clearly sound is not something I am able to answer well.
He is looking to spend 250-300 USD. He would like to have good audio for playing games and a good mic on a boom for microphone. I do not know anything about audio so lets hear some recommendations. Good sound in and good sound out - wired ideally.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1545466-streaming-audio-recommendation/
Hi, $250 seems like too high of a budget for a gaming headset. I can recommend this one, the MASSDROP X SENNHEISER PC37X, really good audio and a mic, with the only downside maybe being that its wired.
Here is a good video review of it in action. https://www.youtube.com/watch?v=spktoWVAlTU
Qoute my reply if you want me to answer back.
The goal is to have 250 for like a headset, a mic, and a mic arm for desk.
Main Gaming Machine
I totally dint read through it all, my recomendations would be the following:
  • For the headset: same as the one I had already linked. $80
  • Microphone: Audio-Technica AT2020USB+ $90 + AT2020 Shock Mount $13
  • Boom Arm: Rode PSA1, $100
If it goes a little over budget you can always buy a cheaper boom arm, I just know the pain of having a cheap squaky boom arm so Im recommending a safe bet.
I hear the audeze maxwell is the best all in one wireless solution
If you want wired I would go with the rode nth-100m and you could even get a dac/amp or game focused dac/amp lilke the schiit fulla but no amp or dac is required
another option is pick any audiophile headphone and throw an antlion boom mic on it, you can do a lot with a $200-250 headphone and a mod mic
Audio go Brrrrrr
18 hours ago, Cocococo said:
Look around for Audeze Maxwell, they're easily the best headset on the planet
I mentioned the audeze Maxwell to the cousin and he ordered them on the spot. They should arrive sometime in January due to back order. He will do a mic and boom later!
Thank you everyone for the suggestions! (You too @Yua)
Main Gaming Machine
