laptop GPU fan rattling with heavy vibration
Solved by thevictor390,
Probably bad bearings in the fan, fix by replacing fan.
If you take the fan out and shake it, there should be no vertical movement at all. If you can feel it moving even a tiny bit it's bad.
Featured Topics
nick name ·
Posted in Networking2 -
1
2
8
Cyber Akuma ·
9
ave11 ·
Posted in Troubleshooting1
play_circle_filled
Latest From GameLinked:
Are you excited for Doom: The Dark Ages? - Gamers 2 Gamers
