6 hours ago, whispous said:
Can you list precisely which folder he's getting this on
the steamlibrary folder on his second drive, the whole folder wont work
edit: he managed to fix it, he checked the whole drive for errors via windows properties
https://linustechtips.com/topic/1544975-problem-with-steam/#findComment-16231900
sounds like drive might be on its way out
id start hunting for a replacement
current main system: as of 1st Jan 2023
motherboard : Gigabyte B450M DS3H V2
CPU: Ryzen 5 3600
ram : 16Gig Corsair Vengeance 3600mhz
OS :multi-boot
Video Card : RX 550 4 GIG
Monitor: BENQ 21 inch
https://linustechtips.com/topic/1544975-problem-with-steam/#findComment-16235237
15 minutes ago, GanjajoggiBig said:
I would if I could but I dont know a reliable program for that
macrium reflect, its free, simple, reliable (never had issues)
edit: actually it seems to be not free anymore.
im sure there are alternatives tho.
-Scott Manley, 2021
https://linustechtips.com/topic/1544975-problem-with-steam/#findComment-16236918
