Help with Budget Build
Go to solution Solved by Queen Chrysalis,
If your looking to optimize on budget, thry this:
  • get a 5700xt on ebay instead of the 6600. A little faster and a lot cheaper.  This one is usually abailable an the cooler is great, and it has a lot of white accenting to match that cooler.
  • the 5600 should be the aame as the 5700x in pretty much everything woth these GPUs.  You could swap the 5700x back in if you want.
  • 2tb nvme for more space, and the 2tb was $80 instead of a $45 1tb
  • this case actually includes fans and has some room for airflow in the front.  I’ve built in it before and it’s great.
  • blue ram to match the blue LEDs.  It’s the same RAM and the same price
  • Much better version of that PSU.  The thermaltake smart are usually terrible, but the BM ones decent.  The BM3 has a new PCIE 5.0 connector for if you ever get a newer GPU.  If you want a much nicer PSU this is a decent deal right now, and could run any GPU you wanted if you upgraded later: https://pcpartpicker.com/product/4XsV3C/be-quiet-pure-power-12-m-850-w-80-gold-certified-fully-modular-atx-power-supply-bn505
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($129.99 @ Amazon)
CPU Cooler: Thermalright Assassin X Refined SE ARGB 66.17 CFM CPU Cooler  ($19.69 @ Amazon)
Motherboard: ASRock B450M/ac R2.0 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: Silicon Power XPOWER Turbine 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($51.97 @ Amazon)
Storage: Crucial P3 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: Sapphire NITRO+ Radeon RX 5700 XT 8 GB Video Card  ($130.00)
Case: DIYPC F2 MicroATX Mini Tower Case  ($35.99 @ Newegg)
Power Supply: Thermaltake Smart BM3 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($59.99 @ Newegg)
Total: $567.60
Generated by PCPartPicker 2023-11-30 00:57 EST-0500
Budget (including currency): <800
Country: USA
Games, programs or workloads that it will be used for: mainly coding and paradox games
Other details
I made a post before, but I’ve spent a while and used the suggestions to make it better. Is there anything I can do that’s better at a low increase in price or cheaper and the same level?
PCPartPicker Part List: https://pcpartpicker.com/list/7QNmFs
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($169.00 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($51.97 @ Amazon)
Storage: TEAMGROUP MP33 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($45.99 @ Amazon)
Video Card: ASRock Challenger D Radeon RX 6600 8 GB Video Card  ($189.99 @ Newegg)
Case: SAMA Sama-S88-BK ATX Mid Tower Case  ($38.95 @ Newegg)
Power Supply: Thermaltake Smart 600 W 80+ Certified ATX Power Supply  ($41.99 @ Amazon)
Total: $617.57
https://linustechtips.com/topic/1544359-help-with-budget-build/
37 minutes ago, Linuswasright said:
Total: $617.57
So you still prefer as low as possible or do you dont mind if we go aggressively at 800$+5%? We can get a lot of juice with 840-850 range.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16227576
Total: $567.60
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16227753
Sorry, just woke up
I think try to hold it in mid 700 or less is good, but the lower you can go with it still being a decent increase in power is the goal. Thanks for help, I’ve been running in circles for the last day or two
had to edit cause my budget went down a bit
Edited by Linuswasright
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16227904
Total: $567.60
Idk where you’re getting the number for the gpu, when I look it’s round ~200 or 160/180 dollars (even on eBay)
case and power supply look good
i don’t really have a use for the extra terabyte, the games I play are tiny and the only other thing I do is code
im going to sty with the 7 because it’s better by like a decent margin
thbj for helping! 🙂
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16227910
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($159.98 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: MSI PRO Z690-A WIFI DDR4 ATX LGA1700 Motherboard  ($169.99 @ Newegg)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($42.99 @ Best Buy)
Storage: Crucial P3 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($54.99 @ B&H)
Video Card: PowerColor Fighter Radeon RX 6650 XT 8 GB Video Card  ($219.99 @ Amazon)
Case: Fractal Design Focus G ATX Mid Tower Case  ($59.00 @ B&H)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $840.83
Generated by PCPartPicker 2023-11-30 07:30 EST-0500
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16227945
Total: $840.83
Sorry I’m new to pc building so I’m wondering a couple things that might be super obvious:
Why’d you decrease the ram?
Why the i5 over the Ryen 7?
From what I got from the other guys in this thread and the gpu I had (forgor the chip) is basically equivalent without having to cut costs on other stuff
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16227981
Here is with 32GB ram build.
12600KF is basically the same as 5700X in my opinion. 12600KF is a little bit cheaper and thats why I chose it.
6650 XT is now on a good price and its basically overclocked 6600 XT which will give you more performance
Total: $849.81
Generated by PCPartPicker 2023-11-30 08:33 EST-0500
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16228020
thbj for helping! 🙂
The 5700xts are are about $150 right now on ebay, so yeah they went up a bit.
the 7 is better in that it has 2 more cores, but IDK what you’re gona do that’ll use them.  Anything outside of gaming will be done flawlessly on a theead or two, and most games still aren’t running any faster on 8 cores than 6 (you’ll see small improvements only because of more cache, but usually the game will be GPU bound anyway, so it’ll never actually happen).
The 12600kf seems quite a bit faster in almost every game.  I only went with the 5600 in my build because that b450mac is only $60, and a wifi board worth using for the 12600kf is like $130.  But with most GPUs for this budget the difference won’t matter.
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16228259
I do a decent bit of ai coding, so I’m fine with the 5700x costing a bit more if it helps with training speed, n the goal for this guy is to future proof him a bit, and i know they’ll use the cores eventually. Thank for taking the time and writing it out though, it’s really helpful to know!
edit: totally agree on the motherboard, the i5 looks cheaper but factoring in everything it costs more in total
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16228369
Motherboard: ASRock Z690 PG Riptide ATX LGA1700 Motherboard  ($124.99 @ Newegg)
Video Card: ASRock Radeon RX6700XT CLD 12G Radeon RX 6700 XT 12 GB Video Card  ($299.99 @ Newegg)
Case: MagniumGear NEO AIR (2023) ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.90 @ Newegg Sellers)
Total: $846.71
Generated by PCPartPicker 2023-11-30 13:19 EST-0500
4 hours ago, greeatzy said:
considering a cc560 is the same price I wouldn't get this
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16228375
Total: $846.71
I think I’m going to stay around with what I have now, but it looks great if I could afford it lol! Sorry about the budget change, something kinda last minute happenedd
https://linustechtips.com/topic/1544359-help-with-budget-build/#findComment-16228387
