HP i7-1250U clocked at 1.70 ghz... help!
Go to solution Solved by da na,
Hi,
I automated some task for a coworker but it runs extremely slow on her work laptop. It's a HP i7-1250U. The internal clock says it's clocked at 1.70 GHz.
The laptop is plugged in and set at high performance in energy settings.
Anyone know what the hell is happening.  This CPU is supposed to clock at 3.5 and boost at 4.3.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
Depending how her particular laptop's vendor decided to configure the TDP limit, it's very likely hitting that. My laptop with a 1315U was limited to 15 watts and would only go about that far on the performance cores and would stick to a measly 900MHz on the efficiency cores. I ended up getting ThrottleStop and now it'll suck down 30-35w under sustained loads and typically stays around 3.4-3.9GHz on the PC and 2.5-3.1GHz on the EC.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
Both of you thank you!
it's pretty criminal, the Microsoft Surface laptops with 11th-gen i5 chips perform like a midrange Core 2 Quad due to the TDP limit.
