Need help with my build
Hi, this is my first pc build but I did do lots of research and I wont thoughts on it. And my budget is $2000 USD and I won't to do 1440p gaming and play VR 90hz or higher and do sum overclocking.
PCPartPicker Part List: https://pcpartpicker.com/list/XdpJmD
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor  ($401.62 @ Newegg)
CPU Cooler: Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler  ($119.95 @ Amazon)
Thermal Compound: Thermal Grizzly Kryonaut 5.5 g Thermal Paste  ($19.00 @ ModMyMods)
Motherboard: Gigabyte Z790 UD AX ATX LGA1700 Motherboard  ($169.99 @ Amazon)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-7600 CL36 Memory  ($169.99 @ Amazon)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: Zotac GAMING Trinity OC GeForce RTX 4070 Ti 12 GB Video Card  ($729.99 @ Newegg)
Case: MSI MPG GUNGNIR 110R ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Operating System: Microsoft Windows 11 Home Retail - USB 64-bit  ($129.99 @ Newegg)
Total: $1920.50
Total: $1920.50
You won't do any overclocking with that board and air cooling. That cpu can run hot. It's great for productivity such as video editing but the extra four small cores (e-cores) don't do much for gaming.  That MSI case sucks for airflow and you can save money on the RAM while achieving similar results. btw most all new cpu coolers come with a small tube of decent thermal compound.
Try this. Low profile RAM so that it doesn't impede that dual tower cpu cooler.
CPU: *Intel Core i7-13700KF 3.4 GHz 16-Core Processor  ($335.99 @ Amazon)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  ($43.99 @ Amazon)
Motherboard: *MSI Z790 GAMING PRO WIFI ATX LGA1700 Motherboard  ($189.99 @ Newegg)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Newegg)
Storage: *Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($114.99 @ Western Digital)
Video Card: *Zotac GAMING Trinity OC GeForce RTX 4070 Ti 12 GB Video Card  ($729.99 @ Newegg)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($94.99 @ Newegg Sellers)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Newegg)
Operating System: *Microsoft Windows 11 Home Retail - USB 64-bit  ($129.99 @ Newegg)
Total: $1844.91
Generated by PCPartPicker 2023-11-28 00:53 EST-0500
A better look at those components.
https://www.msi.com/Motherboard/Z790-GAMING-PRO-WIFI
https://www.intel.com/content/www/us/en/products/sku/230489/intel-core-i713700kf-processor-30m-cache-up-to-5-40-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG620-BK-ARGB-Dual-Tower-CPU-Cooler-1700-AM5/2022/16082.shtml
https://www.gskill.com/product/165/377/1649234797/F5-6000J3040F16GX2-RS5K-F5-6000J3040F16GA2-RS5K
https://www.westerndigital.com/products/internal-drives/wd-black-sn850x-nvme-ssd?sku=WDS200T2X0E
https://www.zotac.com/us/product/graphics_card/zotac-gaming-geforce-rtx-4070-ti-trinity-oc
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
https://lian-li.com/product/lancool-216/
  • 2 weeks later...
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($187.97 @ Amazon)
CPU Cooler: Xilence M705D CPU Cooler
Motherboard: MSI MPG Z790 EDGE WIFI ATX LGA1700 Motherboard  ($299.99 @ B&H)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-7800 CL38 Memory  ($164.99 @ Newegg)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($129.99 @ Adorama)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  ($959.99 @ Newegg)
Case: Zalman S3 ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: Deepcool PQ1000M 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Newegg)
Case Fan: ARCTIC P12 Silent 24.1 CFM 120 mm Fan  ($10.76 @ Amazon)
Total: $1995
OS: FreeBSD 13.3  WM: bspwm  Hardware: Intel 12600KF -- Kingston dual-channel CL36 @6200 -- Sapphire RX 7600 -- BIOSTAR B760MZ-E PRO -- Antec P6 -- Xilence XP550 -- ARCTIC i35 -- 980 PRO 500GB
a 12600k won't be enough for a 7900 xtx at 1440p. A 13600k might be
just get a case with some fans like the 216 and then don't bother with these
Also this case has a solid front panel
and $300 on the mobo with a $190 cpu?
I'd much rather get a Thermalright PA120 than this image.png.37feb2a211d27a236b5b93db4b9f0b6d.png
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
