First build
On 11/26/2023 at 12:47 PM, tommatotje said:Hey, so recently i've put together a list of components for my first pc build with some help from people on this platform.
I was wondering if you guys had any comments on this build? Please let me know if there is something i could change. :))
https://be.pcpartpicker.com/list/BpNpmD
(PS: The reason why i need 8tb of storage is because i'm an editor/gamer so i need alot of space.)
The build looks good, but I don’t see a reason to use such an expensive AIO for the Ryzen 7 7700 non-X CPU since it is almost as expensive as the CPU itself. I would suggest switching to something like a Thermalright air cooler in white to match your white-themed build. If you are doing editing, I would honestly recommend going for a Ryzen 9 7900X or X3D model, but that depends on your budget.
