As it says in the title, i'm building my first pc. I've been researching compatible gpu's, cpu's, and everything else and I want to see if there would be any problems with what I have so far.
CPU: Intel i7 12700k 12th gen
GPU: MSI GeForce RTX 3060 Ventus 2X 12G OC
RAM: Kingston Fury Beast RGB 16GB 6000MT/s DDR5 CL40 DIMM Desktop Memory 2 x 8 GB
Motherboard:  Gigabyte - Z690 AORUS ULTRA Motherboard
For cooling, I have no idea what to get for this, appreciate it if you guys help me out a bit here. Same for the case.
edit: no idea what to do for the storage either, or the PSU
thanks, jdog
Edited by jdog_pg
forgot stuff in the original message
https://linustechtips.com/topic/1542887-building-my-first-pc-p/
thanks, jdog
This dosn't seem like a great value build.
A Z690 board is very expensive and not worth it for the price point you seem to be buying in.
A 3060 12GB is just a bad value.
DDR5 ram is an expensive pick and dosn't add that much performance.
At this price point your better off going for B series motherboards, non X AMD 5000 series CPUs and DDR4 ram.
What is your budget and where are you buying?
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218863
If you want to go 12th gen, I'd choose a cheaper motherboard. 16GB is not usually good value either.
The PSU in my spec is way overkill, but a decent discount.
Suggestions for case, cooler included.
PCPartPicker Part List: https://pcpartpicker.com/list/ZvTL4M
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($153.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: ASRock Z690 Phantom Gaming 4 ATX LGA1700 Motherboard  ($99.99 @ Newegg)
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.99 @ Newegg)
Video Card: Sapphire PULSE Radeon RX 7700 XT 12 GB Video Card  ($429.99 @ Amazon)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: Phanteks AMP v2 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Newegg)
Total: $976.85
Generated by PCPartPicker 2023-11-23 18:53 EST-0500
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218867
I'm trying to keep the costs of everything below 1000 dollars, but I could go over if needed. I'm kinda new to all this PC stuff, and i was going to buy the parts from Amazon, is there any other sites that could be used to look for parts?
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218868
The PSU is way overkill, but a decent discount.
Total: $976.85
I'll take a look at all this, thanks!
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218870
These would be my recommendations, The first has better PSU and storage, and the second has a better CPU and cooler
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($127.53 @ Amazon)
Motherboard: ASRock B550 Phantom Gaming 4/ac ATX AM4 Motherboard  ($84.99 @ Newegg)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($31.97 @ Amazon)
Storage: Samsung 980 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($78.86 @ Amazon)
Video Card: ASRock Challenger OC Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ Newegg)
Case: MagniumGear NEO AIR (2023) ATX Mid Tower Case  ($39.99 @ Newegg)
Total: $978.32
Generated by PCPartPicker 2023-11-23 19:11 EST-0500
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($169.00 @ Newegg)
Storage: Acer Predator GM7000 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($53.99 @ Amazon)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.90 @ Newegg Sellers)
Total: $1003.73
Generated by PCPartPicker 2023-11-23 20:09 EST-0500
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218872
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($96.99 @ Newegg)
Total: $960.32
Generated by PCPartPicker 2023-11-23 18:59 EST-0500
This is what I'd get.
nice, thanks man!
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218874
Just now, jdog_pg said:
nice, thanks man!
Added a second build to that post 🙂
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218875
do you have any idea whatd i do for cooling though? im new to all this edit: oops nevermind im just dumb 😂
Edited by jdog_pg
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218878
A 5700X is roughly a 12600K equivilent, but a 7800XT is roughly equivilent to a 4070 (but with more vram, so it should be relevant for longer)
The first of my builds includes a 5600 CPU which will come with a stock cooler (it's easily enough for that chip). The second includes a 5700X, which dosn't come with a cooler, so I added a Thermalright Peerless Assassin 120 SE CPU Cooler which should be more than enough for that level of chip.
The case may come with fans, if it dosn't I suggest building it, seeing if the thermals are good and then if not you can always add some more fans later to unlock extra performance.
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218879
First build has been updated with an idea stolen from @Tetras. That Phanteks amp v2 1000W PSU is a bargain.
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218883
https://pcpartpicker.com/list/hVYsmD
12600kf + 4070 + 32gb 3600c18
You can swap the 4070 out for a 7800xt, might even be able to find a good deal on a used 3090
Not worth buying as it doesnt have a 10 year warranty
Id reccomend the thermaltake Gf3 1050w as its at 121$ but also has a 10 year warranty and its got a slightly higher wattage
If you want a cheap 1000w then thatd be the apevia prestige/galaxy since those are priced low enough to jistify not having a 10 year warranty and also priced somewhat competitively to used 1000w units
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218904
It does have a 10 year warrenty from what i can see
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218910
12600kf seems a decent value atm
but i don’t think 32GB of ram is worth it at this price point
And I’d take a 7800XT over a 4070, it just seems the better value and long term option.
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218922
15 minutes ago, Somerandomtechyboi said:
newegg only says 5 years for labor and parts
Whist for the GF3 it says 10 years for both labor and parts
That’s just neweggs parts and labor. The manufacturers warranty which you get as well, is 10 years.
https://www.phanteks.com/Amp-Series.html
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218932
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($140.00 @ Newegg)
Motherboard: MSI PRO B760M-P DDR4 Micro ATX LGA1700 Motherboard  ($99.99 @ Amazon)
Total: $989.73
Generated by PCPartPicker 2023-11-23 20:07 EST-0500
12600K build 🙂
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218934
Welp the gf3 is only a little more and offers abit of extra wattage so id still go with that, but good to know the amp series actually has a 10 year warranty, they just do a really bad job of actually advertising it though
16 minutes ago, will0hlep said:
But this is absolutely not worth buying at that price and its also got a 7 year warranty, atleast get the rm or rmx if you wanna overspend on corsair psus so youll atleast have a 10 year warranty
Btw the be quiet 12m 850w is at 89$ (the one in my list) and it has a 10 year warranty and more wattage
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218948
Yeah, that’s a better PSU, I’ll alter the earlier post. 🙂
Useful Websites:
Bio:
Fun Facts
https://linustechtips.com/topic/1542887-building-my-first-pc-p/#findComment-16218952
