New build, help with RAM selection
5 minutes ago, Live_2_Feel said:
1) does it mean that if I install 2 sticks with frequency 7600 in dual channel mode - I will waste it and will get max 6400?
meaning there’s no point in buying 7600 RAM and target 2x16 6400 Mhz?
1) and if in the future I would add 2 more same sticks - I would again lose in frequency from 6400 to 5600?
No, that's what they say it's most likely to work. When you go to BIOS and enable XMP the RAM will still run at whatever speed it's configured to... but it may not work well or at all the higher you go with the speed.
For 2 sticks of Single Rank memory you should be mostly fine up to 7600MT/s but for 4 sticks of RAM that may not be achievable at all as the more sticks you add the more stress there is on the memory controller.
