2 minutes ago, NavyCobra1417 said:
RX 6700 XT
You could make the case for the 3070 if you would benefit from DLSS, RTX, or Nvidia video encoding advantage.
However the 6700XT has great raster and more VRAM than the 3070
can it be 600w or do I have to get a stronger one?
https://linustechtips.com/topic/1542541-gpu-help/#findComment-16216956
10 minutes ago, --SID-- said:
Depends on the quality of the unit. What's the brand and model of the PSU?
8 minutes ago, NavyCobra1417 said:
While the wattage is likely fine; the quality is important. What's the exact model?
Also for 3070 or 6700XT, a quality 600W would be fine.
Enermax  Platimax DF 600W
https://linustechtips.com/topic/1542541-gpu-help/#findComment-16216990
Is this one of your hypothetical builds you seem to have never ending amount of? None of the components you listed match what you got.
https://linustechtips.com/topic/1542541-gpu-help/#findComment-16217028
buddy
it is not hypothetical
it's not for me, but for my brother, but I don't think anyone cares who it's for
https://linustechtips.com/topic/1542541-gpu-help/#findComment-16217055
