PSU power cable broken
Go to solution Solved by Agall,
7 minutes ago, Blakus93 said:
My son's PSU cable is lose and every now and again the pc shuts down can I buy a new cable that runs from the PSU to the wall outlet if it's from the same PSU ? Or will I need to replace the whole PSU ? Thanks
Almost all computer PSUs use a standardized connector. I generally call it an ATX power cable. Tons of other devices use it as well. Only variation will be the gauge of the cable and therefore its wattage/amperage rating. Generally if its a standard thickness cable, it'll be fine for everything but the highest end systems. Then you're looking at 10A or higher cables.
Yes, they're standardized.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1542294-psu-power-cable-broken/#findComment-16215361
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1542294-psu-power-cable-broken/#findComment-16215363
it's not ATX power cable ... the connectors are IEC C13 and C14  (C13 is the plug on the cable, C14 is the receptacle on the power supply with the male pins)  .. in simple terms  C13 plugs into / mates with C14
So you can search amazon or other stores close to you using terms like C13 power cable or IEC C13 power cable or power cord ... example : https://www.amazon.com/s?k=iec+c13+power+cord
example in uk : https://www.amazon.co.uk/StarTech-com-PXT101UK3M-Computer-Power-BS-1363-Black/dp/B00B22TCRW/
I recommend getting one that has wires AWG 18 or smaller (smaller number = thicker wire)... AWG 18 or AWG16  will be good enough for 1500 watts or more.  If the cable is in metric sizes, aim for 1mm2 or thicker.
ps some very high wattage power supplies (1600w or higher) may use the higher current version IEC C19 and C20 pair.... cables look like these https://www.amazon.co.uk/StarTech-com-Computer-Power-Cord-BS-1363/dp/B00KDC0NW0/
https://linustechtips.com/topic/1542294-psu-power-cable-broken/#findComment-16215416
