Riser for 6800 XT in Corsair 5000X
Solved by IkeaGnome,
40 minutes ago, RevGAM said:Does anyone have any suggestions? If possible, I'd like it to mount vertically on the X or Y axis, but the most important thing is that my 6800 XT doesn't block the AIO tubes going to the bottom of the front and right sides of the 5000X.
Display cables would be slightly more annoying to plug in, but I think these would do what you're looking for.
