That's normal.
https://linustechtips.com/topic/154134-help-on-my-gpu/#findComment-2055603
Hi,
not sure if this was posted already in this site. i have a sapphire r9 280x when i check on the device manager it only say amd r9 200 series any way to fix this?
thanks in advance for the help
ya best way to fix this is that u ignore that...bcoz its true... :P ...thats a r9 200 series gpu..isnt it... :P
https://linustechtips.com/topic/154134-help-on-my-gpu/#findComment-2055606
that's totally fine, the way it should be shown, all R9 series from 270 to 290X are R9-200 series just like there are R7-200 series and yeah, welcome dude, hope you enjoy the Forum :D
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/154134-help-on-my-gpu/#findComment-2055626
