PC crashing problem
Go to solution Solved by 191x7,
Latest Bios?
Temperatures?
Hi gamers,
I have a RX 6700 XT from Asus and when I launch Call of Duty MW 2.0 my screen goes black and my pc restarts.I have the latest AMD gpu drivers and still crashes. I tried some old drivers,update the chipset drivers,reinstall AMD Adrenalin,reinstall the latest updates,disableing the hardware acceleration from Brave. I tried reseatting the RAM and it still crashes. I dont know why and im getting stressfull about it. If you have tips,please tell me
My pc specs:CPU:Ryzen 7 5700X
GPU: Asus RX 6700 XT (https://www.asus.com/motherboards-components/graphics-cards/dual/dual-rx6700xt-12g/)
RAM: 32GB 3600Mhz (XMP 3200Mhz) from Corsair Vengeance (https://www.corsair.com/eu/en/Categories/Products/Memory/VENGEANCE-LPX/p/CMK32GX4M2D3600C18)
PSU: Aqirys Pulsar 750W 80+ Bronze (https://www.aqirys.com/product/pulsar-750w)
Motherboard: Asrock B550 Pro 4 (https://www.asrock.com/mb/AMD/B550 Pro4/index.asp)
https://linustechtips.com/topic/1541211-pc-crashing-problem/
Latest Bios?
Temperatures?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1541211-pc-crashing-problem/#findComment-16208680
Try to
Disable hardware acceleration on your apps
Undervolt and Underclock your card through Radeon software. Go for like 1100mV on voltage and 2350MHz on the Clock
Did you also try other games and what is the temps and wattage when you're playing?
https://linustechtips.com/topic/1541211-pc-crashing-problem/#findComment-16208682
31 minutes ago, WackySpace said:
Try to
i dont think my temperatures are the problem bcs i have 50 degrees on CPU and 60 degrees on GPU, if i try tu undervolt it it freezez somethimes and i need to force shut down my PC. The games on that keep crashing my pc are:  Fortnite ,Rocket League, COD MW 2, GTA V
https://linustechtips.com/topic/1541211-pc-crashing-problem/#findComment-16208708
1 minute ago, mananc.portofele said:
i dont have a problem with the temperatures i have 50 degrees on cpu and 60degrees on gpu. About the bios,my motherboard doent detect my usb for the bios update
Is the flash drive formated to Fat32?
https://linustechtips.com/topic/1541211-pc-crashing-problem/#findComment-16208709
35 minutes ago, leclod said:
You could check your memory with a Memtest86 or at least TestMem5.
Maybe your psu is crap, I don't know the brand.
Your system is at stock settings ?
my system is at stock settings. i did put this on an another forum and a few people tell me that its probably my PSU but ill try to test the ram with Memtest86 or TestMem5. i will let u guys updated
https://linustechtips.com/topic/1541211-pc-crashing-problem/#findComment-16208757
I'd try repluging and reseating everything carefully (also psu side)
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1541211-pc-crashing-problem/#findComment-16208764
3 minutes ago, mananc.portofele said:
THANK YOU GUYS FOR HELPING ME
Apparently after I updated my BIOS version everything returned to normal,ive been struggling with this for months
Glad to know it helped. 🙂
https://linustechtips.com/topic/1541211-pc-crashing-problem/#findComment-16212130
