Cpu locked to 800mhz
Solved by unclewebb,
Try checking the MMIO Lock box which is near the top right of the TPL window. Push OK and see if that makes any difference. If you are still locked to 800 MHz, try checking the Speed Shift box in the TPL window.
Your turbo ratios in the FIVR window are lower than the default values. Did you change this in the BIOS on purpose? Push the Defaults button in the FIVR window to reset the turbo ratios to their default values.
Set IccMax in the FIVR window to the max, 255.75 for both the core and the cache.
Uninstall any MSI Control software if you are using that.
