Monitor lose signal when TV turns on?
7 hours ago, Sawa Takahashi said:I don't know which model of 4060 you have but I encountered similar issues with older cards.
Even if the card has 4 display connectors on the back, it can only support a limited number of monitors plugged at the same time. If your card has 4 ports it may support only 3 monitors for example. Also, there may be shared ports like HDMI and Displayport 1 can't be used at the same time.
I suggest you have a look at your manual or reach the manufacturer to know what configurations are supported.
Have a nice day !
The model I have is the MSI RTX 4080 Gaming X Trio. I read the specifications but there isn't something obvious that points to it. But thanks to your comment I suspect it is a bandwidth or interference issue. Monitor #1 was plugged very next to the HDMI port. I now have the very next port to the HDMI one empty and I haven't encountered issues so far. I will report back if something changes.
