(Australia) Help! First time building a PC, aiming for 1440p gaming
8 hours ago, Nay-Nay9 said:I would probably look for a cheaper SSD (maybe a crucial p3)
To quote XqC: And then what? You saved a whopping 5$, for a significantly worse 50% full read and write speed and latency, and you ended up not getting a better PSU out of that. Compression should really only start in the final phase where we got the best performing component that we could without compromising what you want to prioritize beyond that like looks. And when you do it, you got to make sure that the plus isn't just "its cheaper".
10 hours ago, mudkipscience said:CPU: Ryzen 5600 - Seems to be the best value CPU in Australia, anything Intel is a huge price increase.
But on current generation platform it flips. AU market seemed to have yet get the memo that AM5 board is a bit overboard in price, so LGA1700 relative board specification simplicity edges it out even without accounting that LGA1700 supports DDR4 which is astronomically cheaper in AU.
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor ($429.00 @ Centre Com)
CPU Cooler: Deepcool AG620 ARGB CPU Cooler ($78.00 @ MSY Technology)
Motherboard: MSI PRO B760M-A WIFI DDR4 Micro ATX LGA1700 Motherboard ($248.00 @ Amazon Australia)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($85.00 @ Scorptec)
Total: $840.00
Generated by PCPartPicker 2023-11-12 20:48 AEDT+1100
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor ($515.00 @ Centre Com)
CPU Cooler: Deepcool AK400 66.47 CFM CPU Cooler ($39.00 @ MSY Technology)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard ($316.68 @ Amazon Australia)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($201.10 @ Amazon Australia)
Total: $1071.78
Generated by PCPartPicker 2023-11-12 22:13 AEDT+1100
12 hours ago, mudkipscience said:Motherboard with WiFi 6E, a front panel USB-C header
Ill just cut off to this and go from there. For an obsolete platform, you wanna spend as little money as possible on the motherboard.
12 hours ago, mudkipscience said:I've been told this is the sweet spot for Ryzen 5000
If it werent so tragically priced. 3200C16 is actually a far better value now and either way youre not going to get a massively good quality DRAM chip going for the 3600.
12 hours ago, mudkipscience said:Nice looking case, comes with decent fans from what I've read.
And still chokes like the OG H510. If you want the same archetype, look for Fractal Design Pop Air.
12 hours ago, mudkipscience said:~$1500 Australian dollars for the PC itself, another $500 for things like display, peripherals, speakers, etc.
Combined 2000. Peripherals come and go, PC especially long cycle parts like PSU, Case, CPU Coolers, and Storage is going to be a longer time investment than them. And in that same vein:
12 hours ago, mudkipscience said:(hopefully at 1440p)
12 hours ago, Why_Me said:I would look at a 1080P monitor
+1. And in the case of a monitor, 2nd monitor is life changing to own. So don't toss it to Gumtree once you got your 1440p monitor, get a dual monitor stand instead.
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor ($329.00 @ Centre Com)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($129.00 @ Centre Com)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card ($549.00 @ Centre Com)
Case: Silverstone FARA H1M MicroATX Mini Tower Case ($54.00 @ MSY Technology)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($179.00 @ Scorptec)
Monitor: Gigabyte G24F 2 23.8" 1920 x 1080 180 Hz Monitor ($229.00 @ BPC Technology)
Mouse: Logitech G203 Lightsync Wired Optical Mouse ($35.00 @ MSY Technology)
Custom: Keychron V1 QMK Custom Mechanical Keyboard ($129.00)
Custom: 7Hz Salnotes Zero ($25.00)
Total: $2069.00
Generated by PCPartPicker 2023-11-12 22:38 AEDT+1100
