Need clarification on this audio question
Solved by Heats with Nvidia,
Do you want to connect it in series to the loudspeaker?
If yes, you build a first order highpass filter with the loudspeaker as the resistor and in that case you enhance nothing, you just prevent low frequencies from getting to the sattelite speakers, preventing their destruction and enabling them to get louder because they don`t have to deal with frequencies they can`t produce anyway.
In this case the higher capacitance the capacitor (That also has to be bipolar, by the way, so don`t use the normal cheap polar electrolytic capacitors.) the lower the frequency of the filter, hence the lower the base that gets to them.
