A few months ago I built a budget gaming pc for around $600. I got a FX-6300 processor and decided to overclock it. It is my first time overclocking so I watched and read many tutorials. When I was ready to start overclocking, I first started CPU-Z, Core Temp, and prime95 to run on my cpu at stock to begin with. For some reason in Core Temp it saids my tjmax is 52 degrees!? I started prime95 and watched as the temperature reached 47 degrees but I then turned it off not knowing what would happen if it reached 52 degrees. If someone could explain this problem to me it would be much appreciated.
I have attached a screenshot of Core Temp
AMD FX-6300 @ Stock, MSI 970a-G46 Motherboard, Crucial Ballistix Sport 8GB 1600Mhz, HIS Radeon Hd 7870 Ghz Edition @ 1100/1350, WD Caviar Blue 1tb, Corsair CX600, NZXT Source 220, and a Benq 21.5 Inch Monitor.
https://linustechtips.com/topic/153996-cpu-overclocking-issues/
i know for intel the sweet spot is 80 degrees. Dont know what it is for amd.
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/153996-cpu-overclocking-issues/#findComment-2053858
Well I know I didn't want to hit over 75 degrees (personally) but my tjmax is 52 degrees so........
https://linustechtips.com/topic/153996-cpu-overclocking-issues/#findComment-2053890
You can run 62c, AMD temp sensors are kinda garbage so I'd consider that.
Your 1st core is throttling, you need to disable some things in BIOS. (Cool and quiet, C1E, enable HPC mode)
Also your board isn't really ideal for overclocking FX, 4+1 phase VRM from MSI is not good :/
https://linustechtips.com/topic/153996-cpu-overclocking-issues/#findComment-2054108
