Budget (including currency): Up to 4000-4500 PLN
Country: Poland
Games, programs or workloads that it will be used for: Mostly gaming, CS2, Cyberpunk, Lineage II, other MMOs
My current setup:
Motherboard: MSI B360 Gaming Plus
CPU: Intel Core i5-8600k
GPU: MSI GTX 1660 Ti Gaming X 16GB
RAM: GSkill Trident Z RGB 16GB RAM
Case: Silentium PC Regnum RG4 RGB
Power supply: SIL PC VERO M2 600W MOD BRONZE
SSD: WD 1TB M.2 PCIe NVME Blue SN570
I am a gamer, who's started to finally earn some decent money - therefore I am looking to upgrade my motherboard, CPU and GPU. Here are the things that I chose based on some online guides and rankings:
Motherboard: Gigabyte B760 GAMING X DDR4
CPU: Intel Core i5-13500 2.5 GHz
GPU: MSI GeForce RTX 4060 Ti Ventus 3x OC 16GB GDDR6
Are those picks any good? Also, would I need a new power supply for those upgrades or will the current one be good enough?
One more thing - CPU cooling - currently I have SilentiumPC Fera 3 120mm - should I upgrade it too?
I am open to all suggestions!
https://linustechtips.com/topic/1539439-upgrading-my-current-rig-need-help-though/
9 minutes ago, kden said:
Thank you brob, is CPU/GPU/MB combo good though?
Nothing wrong with the choices. Everyone has different preferences. Many might suggest an RX 7700 XT GPU instead of the RTX 4060 Ti for a gaming system. But that would depend on local pricing.
Going 13th gen on DDR4 is pointless. Better drop to 12th gen like 12700k or even better - go AMD with the 5800X3D if gaming performance is what you are after:
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  (€313.99 @ Amazon Deutschland)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  (€38.29 @ Amazon Deutschland)
Motherboard: Gigabyte B550M AORUS ELITE Micro ATX AM4 Motherboard  (€99.76 @ Amazon Deutschland)
Video Card: XFX Speedster QICK 319 Core Radeon RX 7800 XT 16 GB Video Card  (€547.99 @ Mindfactory)
Power Supply: SeaSonic FOCUS GX 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€106.04 @ Amazon Deutschland)
Total: €1106.07
Generated by PCPartPicker 2023-11-06 20:10 CET+0100
With DDR4 you are really suffocating the 13500. In 95% of the cases it needs DDR5 to perform. In very few games it's performing on par with DDR4 memory. 13500 + DDR4  + 4060Ti will be about 35%-60% slower than 5800X3D + 7800XT on the same memory.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
