Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
well its more like i wanted to build a mini itx build for my tv i have a merc 7900 xtx but its kinda big im just looking around for mini cases that can fit it i believe its 344mm any suggestions would be helpful
https://linustechtips.com/topic/1539211-mini-itx-build/
Country:
There are a number of mini-ITX cases that can handle the GPU. But CPU cooler requirements are also a limiting factor.
https://linustechtips.com/topic/1539211-mini-itx-build/#findComment-16193574
You'd need a little more info. Other components you want to add, size restrictions, desired features, etc etc.
The case world is extremely vast.
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1539211-mini-itx-build/#findComment-16193642
